REM is a finish in conjunction with special chemicals.
Is it legal in IT for anything other than the engine? I tried to search this but nothing came up.
Good band....
If you can't find an allowance, IIDSYCYC...
IIDSYCYC: "If it doesn't say you can, you can't"
i.e. exactly that. If there's not something in the rules that says you can REM finish a gear or connecting rod or whatever, then you can not do it.
Cue Kirk. And Andy. And Greg. And me. etc etc. yes, a book that says 'Anything not allowed in these rules is not allowed" shouldn't then go and list specific things that aren't allowed. Logic fail.
It makes the reader say, "Oh, in this area, you can't do this or this, but they didn't say I couldn't do THAT, so I guess I can!".
There are a few of those items in there.
Unfortunately the GCR was written eons ago and is now updated by about a bazillion different people. some have one way of thinking, some have another. this leaves this 'living document' with a lot of ambiguity.
I looked at the REM process, looks like you just drop the part into a vat of ceramic beads, then apply a special reagent for the final few minutes. Dan, if you're planning on doing this to the final drive, then any gear set that fits is allowed.
As an aside, where does the ITCS allow crank polishing? When you have a machine shop check the bearing journals, they'll polish them to remove any scufs. But this isn't mentioned anywhere.
The two gear systems that can use the REM process in IT racing is the transmission & the diffs, transaxle for Porsche's. Since it is not a paint, coating or plating it would think it would be allowed. This "If it doesn't say you can, you can't" is like a parent saying don't do as I do, do as I say. Which was BS even when I was little. 8~) I just want to get this in the open and clarify it.
And it's really not Dan. The whole ITCS is predicated on the very first principle of the rules:
"The following modifications are authorized on all Improved Touring Category cars. Modifications shall not be made unless authorized herein."
If it doesn't say you can, then you can't.
REM is a type of finish and i would have a hard time saying you can't.
on the engine, that would be different;Quote:
No interchange of parts between assembliesplated)
is permitted, and all parts of an assembly shall be as originally produced
for that assembly (such parts may, however, be coated, painted or
so if you can coat/paint/plate parts, why not REM? because of the way the finish is achieved?Quote:
The application and/or use of any painting, coating, plating,prohibited.
or impregnating substance (i.e. anti-friction, thermal barrier,
oil shedding coatings, chrome, anodizing, etc.) to any internal
engine surface, including intake manifold internal surface, is
Exactly. It tells you the WAY you can modify the parts, not the result (color, kind of plating or coating).
Basically it tells you what you can do, and 'micro-polishing' is not one of them. You aren't going to 'coat, plate, or paint' your tranny gears anyway.
And REM is not a type of finish, it's a PROCESS. LOL
REM is a very refined polishing process. Nothing is deposited on the surface and nothing is changed on the base material. So any/all statement specifically stating coating, anodizing, painting, etc. does not apply to this process. The only premise to use for this process not being legal is that it falls under the unauthorized modification umbrella, except for R&P's.
Worth mentioning is the REM can make parts too smooth and that there is a diminishing return on the ultra polished surface finish. The example is some gearbox and R&P results from NASCAR that show REM gears fall back to a rougher surface finish after running the cars with REM processed gears. Get well maintained used parts and the friction surfaces will be polished as a result of regular use.
A side benefit could be oil shedding, but that is tough to quantify.
