i just put in a new oil pan and was reattaching the right motor mount. i have a haynes manual for the torque specs. it gave me the numbers for the mount to engine bolts but i cant find the torque for the mount to frame nut. I already stripped one! :mad1: lucky i have a spare anyone know the torque or where i can find it?
thanks
Matt, very interesting question. I looked at my 1985 Mazda workshop manual & find nothing. Except within the Tech data in the rear of the manual it has torque specs for different size mm nuts/bolts that are not a spec else where.
Unless otherwise specified
6T (I don't have a clue what 6T means unless it's a hardness.)
6 mm 5 to 7 ft lb
8 mm 12 to 17
10 mm 23 to 34
12 mm 41 to 59
14 mm 56 to 76
8T (I don't have a clue what 8T means unless it's a hardness.)
6 mm 6 to 9 ft lb
8 mm 13 to 20
10 mm 27 to 40
12 mm 46 to 69
14 mm 75 to 101
34-49lb/ft.
I usually put them on with an impact. :unsure:
