Rear Axle seal Leaking/seeping
Have left rear axle seal leaking (1st Generation 84/85 disc brake axle)have replaced the seal several times used Napa seal switched to Mazda Factory seal even replaced the rear wheel bearing since the seal in the bearing looked like it had a small indentation in it. The Axle Flange plate has no Gasket and wondered if that might be the problem. Doesn't seem to loose a great amount but I don't like the idea of it leaking and lubing up the track. Have inspected the housing can seem to see any marks in seal seat area. Anyone offer some suggestions?
Tom Weaver: Logistics & Technical Support Manager IE truck driver for 1980 RX-7 ITA #63
"Hemi haulin' Rotary"
